Rear coil-over conversion...
Old 10-05-2012, 09:38 PM
Venomantidote95
Venomantidote95's Avatar
Default Rear coil-over conversion...
Anyone here done just a rear coil-over conversion on there fox or sn car?
Wondering how you like it and did it help with planting the rear tires consistantly and evenly?
Venomantidote95 is offline
Old 10-05-2012, 11:53 PM
darkmach1
darkmach1's Avatar
I did it, but haven't tracked the car to find out, drives good though.
darkmach1 is offline
Old 10-06-2012, 12:57 PM
Boss_Hotrod
Boss_Hotrod's Avatar
Ive got a set from MM/bilstien but I also have everything else so I aint much help either. Seems to make the car bounce a little more but I dont have any weight at all in the rear. Cant speak on planting power due to the other parts.
Boss_Hotrod is offline
Old 10-08-2012, 10:39 PM
cmc87
cmc87's Avatar
Are you considering for drag or autocross? IMO better suited for autocross, mostly 'cause there are cheaper options for drag that work just as well.
I can tell you for street manners they aren't very enjoyable. Like the others have said, around town they are harsh. For a serious racing machine, yes, they'll help once you get all the adjustments dialed in.
cmc87 is offline
Old 10-10-2012, 01:06 PM
Venomantidote95
Well it is my DD in my avatar and sig the current set is drag launch single bagged system with lakewood shocks and struts, 70/30 and 50/50... The engine just overpowers the current setup and cant get any better than a 1.76 60ft! need to be down to atleast a 1.60... this is n/a i want to spray it but if it wont hook before it probably wont then and be even worse! I dont want to go to a slick, there are plenty of more powerful cars around here using drag radials but they have done the coil-over rear upgrade... I dont see many highway speeds or highspeed turns or curves where i live so i guess it wont change my riding comfort much!???
I`m going to try some trackbite but thats a hassle unless you have a friend go with you to the staging lanes every run!
4cylinderplus2
10-09-2020 07:45 PM
baddog671
07-26-2016 01:20 PM
flash_xx
10-16-2015 07:23 AM
UrS4
09-30-2015 10:13 AM
lincolnshibuya
09-24-2015 10:46 PM
Quick Reply: Rear coil-over conversion...
