fuel pressure goes down when hitting the gas
I'm running stock heads and cam, stock injectors, sn-95 maf. It's 38psi with the vacuum on. It's just weird because this is the first time it has ever done it. Never had a problem all summer. When the vacum is off it goes up to about 42. The pressure does go back up after I rev it up
Timing is at 14 degrees..plugs looks good. It's a sn-95 maf and housing. It's just weird that this is the first time it has ever ran like this...never had any problems till I went to adjust the fuel pressure
No this regulator has been in since April and was brand new when I installed it...it only started doing this when I went to adjust the fuel pressure. The fuel filter was done in may when I put in a Walbro 255
I put the pressure up to 50 with vacum on to see what would happen...when I reved it up the fuel pressure went up like it should have ... I turned it back down and back to the same problem. Fuel pressure went down went I hit the gas. Why won't the regulator let me put it any lower than 38 psi?
