compression
Old Sep 28, 2005 | 08:03 PM
StangStang's Avatar
StangStang
Default compression
I am doing a compression test on my 92 mustang lx 5.0 I know the compression is 9:1 but what should I be looking for on the compression tester in Psi??
Old Sep 28, 2005 | 08:40 PM
EADracing's Avatar
EADracing
Default RE: compression
ORIGINAL: StangStang
How much psi depends on the motor and how old it is. I would just look for something above 100 psi and every cylinder VERY close to each other.
Old Sep 28, 2005 | 08:56 PM
posnick's Avatar
posnick
exactly. its not so much the psi but the cylinders should be within 5 psi of each other if not the same. you will probably be around the 125 mark
Old Sep 28, 2005 | 09:13 PM
Quik's Avatar
Quik
120 is hte lowest you want to see and thats a worn motor..... my motor read 30psi so its gone and parts are for sale
Old Sep 28, 2005 | 10:09 PM
StangStang's Avatar
StangStang
ok, on a new engine what should the psi be just for the record. Also where can I get an awesome service manual???
Old Sep 28, 2005 | 11:12 PM
Quik's Avatar
Quik
new motor should be around 150 or so
Old Sep 29, 2005 | 07:51 PM
tinman's Avatar
tinman
You are 'ok' on any used motor if the lowest cylinder is within 10% of the highest one.....
baddog671
Jul 26, 2016 01:20 PM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
bconboy
Sep 21, 2015 12:52 PM
uberstang1
Sep 20, 2015 06:42 PM
1st 4 eyed fox
Aug 24, 2015 06:56 PM
