Shift Kit & AOD
shift kits are for an automatic. they firm up the shifts and delay them too.
aod is a ford tranny and it stands for automatic overdrive. its a 4 speed and is pretty weak in stock form.
a common problem is burning up the stock o/d band by applying throttle while in o/d.
however they can be built up to handle 600 plus hp quite easily.
i have one myself.
i have one myself.
yes they help greatly and i have what you want. alot cheaper then any kit you buy then installing it
its the VB that came out of my strip/street GER AOD. it was replaced with a lentech manual vb
im only asking 40 bucks for it.
drop pan, remove the 21 bolts or so and then install this one. replace gasket and off you go
jwog666
Dec 27, 2021 08:09 PM
Lethaldosage423
Oct 19, 2015 12:12 AM
