Newbie with a unknown modded 5.0
Hello all, I have a 1991 5.0
I am trying to figure out all what is done to the car. The previous owner got it as a trade and didn't know much about the car. I got it for a good price so I couldn't pass it up.
He claims-
Fully Forged internals (assuming I can't confirm this without tearing it down)
What I know-
Cammed, no idea what size. Not too aggressive but enough to hear some chop in the idle.
Eldebrock heads
Eldebrock intake
CAI of some sort
MSD ignition
Shorty headers
Aftermarket exhaust with off road H
Its has a T-5 trans with a short throw (that I installed)
Couple of things, the clutch is VERY stuff (typical?)
I am getting at best 100 miles to a tank (running very rich? too big of injectors? bad/no tune?)
Car has around 127,000 miles, guy claims it was rebuilt at 110.
Any help is appreciated!
He claims-
What I know-
Eldebrock heads
Eldebrock intake
CAI of some sort
MSD ignition
Shorty headers
What I know-
Eldebrock heads
Eldebrock intake
Eldebrock heads
Eldebrock intake
100 miles to a tank ? are you racing it everywhere ? cuz thats about 6 miles per gallon, and it can get 24
those injectors are stock, so no...they are NOT too big LOL
id do a gear check for starters and look for vac leaks
Rearend gears? Sorry forgot to mention. It has 4.56's.
I got the car from Port Huron. I'm from Chelsea, just west of Ann Arbor.
Im pretty sure its cammed. It doesn't jump in rpms during idle, its pretty steady. It stays with my buddies 99 Cobra from a roll. A dig is pretty much useless with the 4.56s and stock tire.
clutch cable may be bad, which is what I find with most stiff pedals, I run a cf/df clutch and pedal is smooth, take the 4.56's out, that'll be a big reason gas mpg sucks, also run a koer test and make sure you don't have any codes that'll contribute to reduced mpg, such as rich/lean codes
Well only way to tell if the car has forged internals is to tear it down and see, but I'm gonna go out on a limb and say no, and here's why, nothing is done to the car to justify forged internals.
As stated the chop in the idel can be caused by a lot of things. One semi easy way to check to see if the car is camed is to break out the most accurate ruler you have and pull off the vale and measure the valve travel. If it traves .440" that's stock, .480 that's in the ball park of b303, .500 that's e303 and so on. This isn't 100% or even 90% but it's a good way to get some bearing as to what kind of cam is in there. Just keep in mind there are a lot of aftermarket 5.0 cams with similar valve lifts but different lobe separations, and valve lifts in dual stages.
You have a major electronic or fuel system delivery problem or a bad vacuum leak causing the fuel problem. That car isn't moded enough, even with a mild cam to see those numbers.
As stated pull the 4.56 gears out, that's way too steep. 3.55s or 3.73s are perfect for performance/street balance.
I've driven a lot of mustangs and a stiff pedal seems to be the norm with stock clutches, but as stated there could be a problem with the clutch cable or other causing it to be overly stiff. If it has an aftermarket clutch I would deffinitely suspect the cable.
