compression ratio ?
Old Sep 30, 2005 | 12:39 PM
OneGearhead's Avatar
OneGearhead
Default compression ratio ?
ok.........the 306 im lookin at, i can get it in ANY compression ratio i want. i was thinkin 10.5:1......but i was thinkin this morning, and could i go ahead and bump it up to 11:1 since im gonna be n/a, or would that be pushing it for 93 octane and would have to start running higher than pump gas ?? mind you, this is gonna be a daily driver, sometimes seeing action at a strip, but more than likely, itll get tested at lights more than a "tree". thanks
Old Sep 30, 2005 | 12:42 PM
83beast's Avatar
83beast
Default RE: compression ratio ?
not totally sure, but my dads 70 mach1 has the fourbbl clevelavd and the heads have been shaved and it runs well on 93. not the absolute best, but it has a hot cam too. its been frigged with, so thats prob the main thing. id say 93 works.
Old Sep 30, 2005 | 01:17 PM
JD1969's Avatar
JD1969
Pro. B.S. caller outer
opps double post
Old Sep 30, 2005 | 01:18 PM
JD1969's Avatar
JD1969
What heads are you going to run and what cam? Aluminum heads can get away with more compression that iron due to better cooling and usually a better combustion chamber. The cam will have alot to due with it also, the more overlap the more compression will be bled off. I have run 11.5 motors on 93 pump gas and never had a problem, but that is at the extreme limit, and the car was not a daily driver. If it were me, I would stay below 11.1 since you say it will be a daily driver, you never know you might get some bad gas or somthing and the .5 point is only worth about 10-15 hp, so it's not a huge loss.
Old Sep 30, 2005 | 01:36 PM
dc_mann8's Avatar
dc_mann8
yeah i was gonna say around here they stick to about 10.5, 11:1 at most! we run 92 here, buddys with 11:5:1 run 92 with octane booster.
Old Sep 30, 2005 | 01:45 PM
OneGearhead
ORIGINAL: JD1969
i was thinkin the whole Trickflow twisted wedge/street heat engine kit. twisted wedge heads, street intake manifold, and all that good stuff. Stage 2 TFS cam with 1.72 rr. i might just stick with 10.5:1 then, since its not that much hp diff....but, hp is hp either way....
Old Sep 30, 2005 | 01:51 PM
OneGearhead
heres the kit im lookin at. the guy at trickflow ive talked to, said he'll upgrade to stage 2 cam for me and all the associated stuff for $20 extra dollar
http://store.summitracing.com/defaul...=egnsearch.asp
Old Sep 30, 2005 | 04:08 PM
vfast's Avatar
vfast
I ♥ Acer
a 10-1 set up is enough......or if a dome piston is a must then go with a reverse dome
Old Sep 30, 2005 | 04:23 PM
5.0family's Avatar
5.0family
well with gas prices the way they are if u can afford it go fot it in my book i think 10-1 is enough
Old Sep 30, 2005 | 09:12 PM
Quik's Avatar
Quik
what the hell you going ot do with a 224/236 .542/.563 112 athen add .038 to the mix...i wouldnt run that combo
