recommend me a clutch/flywheel? 347-T5
Old 03-16-2013, 08:13 PM
polo708
polo708's Avatar
Default recommend me a clutch/flywheel? 347-T5
Building a 347 stroker with AFR heads and I have a T5 transmission with Z gears (hoping for 500hp).
What clutch and flywheel do you guys recommend? I'm hoping to aviod hydraulic setups. Looking for a a decent pressure. Don't want a hard clutch pedal feel, but I do want a little something. Its for a street car.
polo708 is offline
Old 03-16-2013, 09:32 PM
STORMTROOPER92
STORMTROOPER92's Avatar
McCloud RST twin-disc setup
STORMTROOPER92 is offline
Old 03-16-2013, 10:32 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
what's the build that has you believing 500 hp out of the combo?? CF DFX is a good clutch if it truely has 500 hp
mjr46 is offline
Old 03-17-2013, 01:01 AM
polo708
polo708's Avatar
347 stroker motors with AFR heads and a comp cam XE274HR are all over the place with outputs over 500 to the crank.
I checked out the DFX and the reviews so far seem to be what I'm looking for. Thanks for the recommendation.
polo708 is offline
Old 03-17-2013, 11:47 AM
mjr46
mjr46's Avatar
which afr heads?? and what intake/carb/efi?? and exhaust size combo??
mjr46 is offline
Old 03-18-2013, 11:11 AM
Boss_Hotrod
Boss_Hotrod's Avatar
Spec stage 3+. Was running that on my mostly stock 93 before I tore it down. Had the same pedal pressure as a stage 1 clutch but grabbed like a SOB. Highly recommend those clutches to anyone. Even put one in a guys G35 at work.
Boss_Hotrod is offline
Old 03-18-2013, 02:44 PM
bluebeastsrt
bluebeastsrt's Avatar
Stay away from clutch master. Biggest piece of junk out there. I had good luck with the spec clutchs.
bluebeastsrt is offline
Old 03-18-2013, 04:17 PM
Duncan_GT
Duncan_GT's Avatar
I've read Spec clutches have a lot of chatter, is that not so much?
OP - I have a Ram aluminum flywheel. I think it weighs 14 lbs
Duncan_GT is offline
Old 03-18-2013, 08:01 PM
Boss_Hotrod
Mine doenst chatter. Ive had worse luck with stock honda clutches chattering that I have spec. Dont know about stock Ford ones since the only stock ford clutch ive driven is in the Boss and its a whole different animal.
Also they make an aluminum flywheel that has a steel insert in it. A few manufacturers have them. Best way to go IMO.
Old 03-18-2013, 08:41 PM
Duncan_GT
Duncan_GT's Avatar
^^my Ram is like this
Quick Reply: recommend me a clutch/flywheel? 347-T5
