88 5.0 High Output head questions
I have recently purchased a 1988 5.0L HO motor and am in the process of refreshing the motor to pretty much stock specs.
Anyone know
valve sizes I would need for stock applications?
spring weight/size for stock
I have tried looking up stock specs, but to no avail.
any and all info would be appreciated... (probably going to carb the motor instead of EFI, unless I find a nice donor LX body that had the 5.0 EFI HO motor)
Thanks
Anyone know
Thanks
I don't know the spec you're looking for, but most folks will tell you that you are wasting money doing ANYTHING to E7 heads.
I realize that's not what you asked, but I'm throwing it out there anyhow. GT-40Ps would be a much better investment.
Ok, Those heads should measure out to 62cc in the chamber as a minimum.
Intake valve is 1.782"
Exhaust is 1.46"
Spring on intake calls for 74-82# with closed valve at 1.78" tall.
211-230#open at 1.33"
Spring on exhaust is 77-85# at 1.60 tall when closed.
Spring when open should be 200-226# when open at 1.15" tall
I'm thinking those are the specs you couldn't find.....
Exhaust is 1.46"
I'm sure they would be however, I'm just refreshing the head because it had a hundred twenty thousand miles on it and I figured the valve springs probably need replacing on it along with that I've also misplaced the valves and didn't keep track of which port they were in so I figure I'm going to go ahead and get new valves for that particular head is well unless I can relap the old valves which I'm not crazy about
Exhaust is 1.46"
Exhaust is 1.46"
yes thank you so very very much that is exactly what I was looking for
I'm gonna beat the dead horse one more time... Especially if you're considering a 3 angle job, and no doubt squaring the heads up, why not spend another $100 and get some GT40Ps instead?
If you REALLY don't want to do that, I'll go away and keep my mouth shut.
let's start a crowd chant...
"Jon!"
"Needs!"
"GT-40"
"Ps!"
Seriously... I'll STFU if you want, but man are you missing the boat to awesome-town over $100....
