Issues
Old Apr 15, 2013 | 08:29 PM
Herkydoc92's Avatar
Herkydoc92
Default Issues
So, my 1994 GT has run into some issues... It's idling really low (500 RPM) and wont stay running for more than a minute.. When i hit the throttle, it just dies... It's weird... I thought it would be an air intake issue, took off the filter and didnt change a bit... Ideas?
Old Apr 15, 2013 | 08:54 PM
adrnlnjnky700's Avatar
adrnlnjnky700
fuel pressure?
Old Apr 15, 2013 | 09:10 PM
Herkydoc92's Avatar
Herkydoc92
hm... i'll have to check it out.. everything else checks out... hopefully it's nothing major
Old Apr 16, 2013 | 12:16 PM
mattdel's Avatar
mattdel
Fuel starvation or plugged cats.
Old Apr 16, 2013 | 03:13 PM
Herkydoc92's Avatar
Herkydoc92
what do you mean by plugged cats?
Old Apr 16, 2013 | 03:23 PM
BabyGT's Avatar
BabyGT
Catylitic converters can become clogged over time. That's what he is talking about. Eventually they will be so plugged up your car won't be able to exhaust and if it can't breath exhaust out it won't have any room to suck air in and run.
Old Apr 16, 2013 | 05:36 PM
Maxwelhse's Avatar
Maxwelhse
It could have suddenly developed a nasty vacuum leak too... Usually plugged cats will slowly degenerate performance until it gets to a seriously noticeable level. Suddenly getting so bad that the car won't run would be a bit strange.
To check for a massive vacuum leak on a carb'd or non MAF car I would block the air intake off partially with my hand, a little at first and then gradually more, to see if it made any difference. I'm not sure how accurate this test would be on a MAF car. Obviously, if it block it off entirely and the car is still running, you have a bad problem (I've seen it!!!).
Old Apr 16, 2013 | 07:08 PM
nitrous_bob's Avatar
nitrous_bob
+1 thats my bet, and im gonna go on a limb and say i bet that 90% of idle probs are vac related
Old Apr 19, 2013 | 08:36 PM
Herkydoc92's Avatar
Herkydoc92
Ive also heard that it could be an o2 sensor....... opinions on that?
Old Apr 19, 2013 | 10:34 PM
mattdel's Avatar
mattdel
Incorrect. O2 sensor input isn't even considered for ECM calculations until closed loop, which occurs at 180* coolant temp. You aren't running long enough to get there.
