Power surging...i think
tfs2 cam, 1.6 rr. gt40y heads ported, hardened pushrods, cobra intake, intake spacer, 75mm tb, and thats basically it. how do you reset the ecm? And I believe I did an idle relearn. I did this
http://www.moddedmustangs.com/forums...dle-reset.html
is that what you mean and idle relearn. No i havnt gotten it tuned yet. but would it run that bad? anybody have a fair estimate on a tune? i havnt checked and im just curius.
thanks again guys.
and is there no way this is a misfire? like ive said ive dealt with misfires before and they were a definite misfire.
thanks again guys.
What heads did you use and intake, there are 2 different intake gaskets for that engine depends on what heads you have .they will both go on,and will run,but will give you the surging.rolling you are talking about ...
one set if for the 4.6 and the outer is for a 4.6 with PI heads... Sorry just seen your last post ,must have been typeing when i was ... vac leak some place,
KingRando
10-02-2015 08:06 AM
09-25-2015 06:58 PM
