questions about vaccum lines......
I have a couple questions about the vaccum lines on a 1994 5.0. The plastic line going to the EGR valve and the one next to it going to the intake manifold have no vaccum, so i figured i better replace them. I know they go into the passenger side fender, where do they come out and how hard are they to change?
RE: questions about vaccum lines......
ORIGINAL: seanjohncombs001
Not sure about 94 but my 00 has an Air pump in the passenger side fenderwell. There is a solenoid on top of it that may need replacing but I've never heard of anyone needing to service it.
sorry wish i could help,but i yanked all that stuff off...i'm not %100,but doesn't one of them go to the charcoal box??or is it just the intake,and gas tank that goes to it?
Easy to change but if they are preformed lines you may have to go to the dealer. Before you go changing those lines, what usually fails is the DPFE (Differential Pressure for EGR) switch. It's black somewhat flat and squarish, typically has one or two vacuum lines attached to it as well as in-line with the EGR metal tubes.
It definitely would on an OBDII but I haven't had much experience on an OBDI with the DPFE. You would get a light with no vacuum too on an OBDII as it would cause leaning out. Have you tried to see if there are any codes stored even with the light off?
Also, when you check the vaccuum from the Intake, is it with the engine idling or with you manually opening the throttle under the hood? At idle you shouldn't feel much of anything. At moderate RPMsis where the most vacuum would be felt. Even then you would need a vacuum guage to get any idea of how much there actually is.
As part of replacing the vacuum lines, you could pop the EGR valve off and clean it out.
ORIGINAL: lunchbox99
egr doesnt get vaccum until your cruising under light throttle. and the vaccum line that goes INTO the intake manifold? explain?
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
treesloth
09-28-2015 07:03 AM
