92 mustang surging problem
Old Jul 3, 2013 | 09:22 PM
mn102483's Avatar
mn102483
Default 92 mustang surging problem
hi all . I just bought a 92 mustang that has a bad surging problem and some times car turns off . when turning ac on car shuts off right away at idle. every once in a while car will not serg and run good but when it does serg car looks like it runs rich with a lot of smoke coming out the fuel gauge on car says about 35 psi and goes up and down as it serges . I have changed the iac. egr .tbs. and the pcv valve and still nothing does any one have any ideas that might help . car has holly aluminum heads that where ported and upper and lower thplon mainifold
Old Jul 3, 2013 | 11:27 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
check for vaccum leaks and what maf and inj's does it have?? stock cam??
Old Jul 4, 2013 | 07:39 AM
mn102483's Avatar
mn102483
Default serging problem
it has a e303 cam 24lbs injectors and bbk mass ais flow sensor calibrated for 24lbs injectors
Old Jul 4, 2013 | 05:29 PM
mjr46's Avatar
mjr46
check for vaccum leaks also, I use a smoke machine to leave no doubt
Diode Dynamics
28
May 26, 2022 12:02 PM
KEM Motorworks
Aug 14, 2015 10:13 PM
fdnyems19
Aug 13, 2015 09:36 AM
defarmer
Aug 13, 2015 06:40 AM
daytooday
Aug 11, 2015 09:22 AM
