Window problems 91' HELP!!
Old Jul 24, 2013 | 02:10 PM
91'LX302's Avatar
91'LX302
Angry Window problems 91' HELP!!
Okay, I have 91' LX and I'm having trouble with the windows going up and down. The drivers side has been not working since I bought the car, I believe it's the motor going to replace today. On the other hand passengers side was working fine till last night. They put freon in it last night, and messed with the fuse panel. They had to replace the AC fuse, after that the window window didn't want to roll back up. (It is still down)
Has anyone had this problem? Or any suggestions on how to fix the problem or what could be causing it?
Any help would be appreciated!
Thanks!
Old Jul 24, 2013 | 02:40 PM
mattdel's Avatar
mattdel
Likely a coincidence. When the motors get tired, they won't go up anymore. They will still go down though.
Old Jul 24, 2013 | 04:04 PM
Boss_Hotrod's Avatar
Boss_Hotrod
Check the bushings in the motors. They are more than likely bad. Also check to see if they run when you pull them out to verify wiring is good. If they wont run check for power and ground before doing anything to the motors.
SSRFUZZY
Members Other Vehicles
Jan 6, 2016 08:22 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
robjh22
Suspension
Sep 8, 2015 12:47 PM
zanemoseley
Sep 6, 2015 12:58 PM
5.0 kevo
Sep 3, 2015 06:24 PM
