Switch Panel install
Old Aug 1, 2013 | 12:50 PM
taff's Avatar
taff
Default Switch Panel install
I am in the process of installing a switch panel on my 95 GT and needing some help. I have a 4 switch panel with main power and start button I want to completely remove the key. I have water pump, fan, and fuel pump wired up but need to know which wires from ignition switch to splice for main power and start button. I have my ignition switch removed from under steering column but don't which switch they need go. On my 95 I have 5 yellow 1 tan/white 2 grey/y 1 big black 1 small black 1 black/white and 1 purple coming from the ignition. Which wires do I need to tie together to run I will just run wire directly from starter relay or maybe start to solenoid from push button but its the other ones I not sure about. I know one goes to EEC do the rest run Accessories? Any help would be greatly helpful so thanks in advance.
Old Aug 3, 2013 | 07:55 AM
taff's Avatar
taff
Nobody knows which wires from the ignition switch need constant power to run the car.
Old Aug 3, 2013 | 08:03 AM
dawson1112's Avatar
dawson1112
Im fairly certain there is only one constant 12v at the ignition switch. The yellow wire.
The rest only get power when in the run position.
Old Aug 3, 2013 | 10:46 PM
Bubba 95SN's Avatar
Bubba 95SN
Lock-unlock steering column will be by what means?
Granatelli Sales
Jan 20, 2020 12:34 AM
copestang
Oct 11, 2015 07:17 AM
TimeLord101
Sep 4, 2015 09:27 AM
Luke9222
Sep 4, 2015 06:46 AM
cbird1177711
Sep 3, 2015 08:43 PM
