95 GT AC vacuum, need help!!!
This is on my 95 GT.
[IMG][/IMG]
As you can see in the above diagram, the vacuum comes in through the firewall and goes to a check valve. My question is where is the check valve located. I have checked the line under the hood and it is good. I have checked the black line at the (HVBC) connecter that is behind the glove box and have no vacume, so some where between the first connector and the firewall is where my leak is.
Where the line goes into the firewall by the two larger lines, where does the line come out under the dash for the check valve and where is the vacuum tank located.
[IMG][/IMG]
TfcCDR
09-14-2015 12:08 PM
