Stalling Problem on my 94
I am about to acquire a 1994 Ford Mustang 5.0 H.O. I am wondering about a problem I am having the car will start up and stay running only for a second and then stall out. The only way to keep it running is to keep giving it gas. After about 10 minutes of running it wont stall but still runs a little ruff but not to bad. The car is an automatic and the previous owner drove alot on dirt roads. I am wondering whatcould be wrong with it, if it could be a fuel pump or a fuel filter or a fuel injector or what you guys might think it could be. I would be very greatful if you could give me some insight. thanks in advance.
one always change the fuel filter, plugs, wires, dist. cap and rotor, air cleaner and oil when you get a used car.
the problems sounds like a worn cap and rotor. my 88 did the same thing.
you could check the IAC. theyre usually gum'd up.
trashxtrash
09-20-2015 10:49 PM
TfcCDR
09-14-2015 12:08 PM
