e303 cam
Old 04-12-2014, 09:50 AM
willhays911
willhays911's Avatar
Question e303 cam
i got a 94 gt 5.0 and im looking to do a E3030 cam swop. planned on changing the valve springs and all that just wondering if there is any one who has some other ways to hop them up a little more then a cam swop, ported and polish heads, full exhaust with shorty headers, and 70mm throttle body?
willhays911 is offline
Old 04-12-2014, 07:22 PM
barnett468
barnett468's Avatar
yeah, mill the heads .028" from stock to increase your compression by around .5.
pocket port and remove exhaust bump if there is one.
24 lb injectors.
barnett468 is offline
Old 04-13-2014, 02:07 AM
dawson1112
dawson1112's Avatar
A set of 3.73 or 4.10 gears goes a very long way in these cars.
dawson1112 is offline
Old 04-14-2014, 07:46 AM
88 orangepeel notch
88 orangepeel notch's Avatar
+1 ^^^
If your still running factory gears, that's definitely the first mod I'd recommend.
I personally wouldn't stick any money into the stock heads unless your REALLY pinching pennies. Even though I'm running E7's that have been worked over and perform very well for what they are, the money the po stuck into these would have got a nice set of aluminum ones
And you won't need bigger injectors till you get up around 300hp at the crank.
88 orangepeel notch is offline
Old 04-14-2014, 08:40 AM
willhays911
thanks for all the ideas! i thought about doing gears and was kicking around 3.55's or 3.73's what would be ideal?
Old 04-14-2014, 09:46 AM
aode08
aode08's Avatar
Your vehicle specifications are not listed in your signature. Do you have a automatic or 5-speed? Any other mods, such as tire/rim no longer factory specs?
Future mods?
Goal for the 1/4 mile?
Also consider you live in Michigan,and Michigan weather.
aode08 is offline
Old 04-14-2014, 10:29 AM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
get some good heads, good intake and better cam ,gears and good exhaust
mjr46 is offline
Old 04-15-2014, 12:20 PM
willhays911
its a 94 gt 5 speed. id like to get around 400hp. not looking for some badass race car just want a good weekend cruiser
Old 04-16-2014, 09:33 AM
88 orangepeel notch
I'd knock your hp goals down alittle bit. If your starting with a stocker, you've got maybe 180-190 at the wheels now, if it's been maintained. I don't know your budget, but I don't think your gonna like the price tag on 400 hp. 300 at the wheels makes for a fun street car with the right gears. And much easier on the checkbook.
And on your last question on gear ratio, 3:73 or 4:10 would put a big smile on your face.
Old 04-16-2014, 09:50 PM
mjr46
mjr46's Avatar
400 hp.......you aren't gonna get even close to that without heads, intake, cam and every bolt on you can think of.......can you get that out of a 302.....sure, but the combo needs to be matched and well thought out and not just thrown/bolted together......meaning special attention to detail and all the little things during assembly must be done........or just go the stroker route, but even then to get 400 rwhp , parts must be carefully selected.
mjr46 is offline
Quick Reply: e303 cam
