95 gt minor problem
It's automatic but I have to start it all the way in first and leave slowly like it's a manual otherwise it stalls for no reason it's like having the three stooges (
) try and tell me how to drive but for how much I bought it for I can fix it hopefully
First thing to do is pull any stored codes in the ecm. http://dfwmustangs.net/forums/showthread.php?t=7908
next step is determine if egr is sticking open, you can pull off the egr valve and clean it. I suggest eliminating it temporarily by putting a block plate in its place. Sounds like egr is stuck open. How does it idle?
Clean the MAF with some special spray for MAF meters you can get at autozone.
Look for vacuum leaks.
Check/test throttle position sensor
69MustangCoupe393cid
Oct 3, 2015 10:33 AM
stangin1996gt
Sep 21, 2015 11:01 AM
trashxtrash
Sep 20, 2015 10:49 PM
LivingInThePast
Sep 16, 2015 12:20 PM
