is it possible
Old 10-13-2014, 01:25 PM
84CopperGT
84CopperGT's Avatar
Originally Posted by mjr46
351 is a 351.....it'll fit right in....now tranny may not....just have your aode rebuilt
not exactly. you have 2 different 351s from Ford. The Windsor and the Cleveland and they are not anywhere close. The only similarities are the bore size and cylinder head bolt patterns.
84CopperGT is offline
Old 10-13-2014, 02:16 PM
95gtconvert
95gtconvert's Avatar
does it change for the 93-95 lightning though is what I'm trying to find out to fit it so I don't have to do a big crazy tunnel re-fab
at most I don't want to have to make the whole thing just where the transmission is
95gtconvert is offline
Old 10-13-2014, 02:23 PM
84CopperGT
84CopperGT's Avatar
you can use a Mustang transmission with the Lightning engine. using the Lightning transmission requires modification
Old 10-13-2014, 02:40 PM
95gtconvert
does it matter which trans
and could I find any 5.8 engine and just put the different heads and intake on it and still have it work or does it have to be a lightning motor to have it work with the mustang trans auto or 5 speed in order to bolt up
Old 10-13-2014, 02:43 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
I'm well aware of the 351c, I thought we all understood he was talking about a 351w since it was out of a lightening so no need to clarify in this case, which is why I wrote what I did......but if it makes you feel better......351w is a 351w all better now??
mjr46 is offline
Old 10-13-2014, 02:46 PM
mjr46
mjr46's Avatar
i'd go for a 351 roller motor out of a 94 ish and up bronco to whenever they stopped putting a 351 in them....not sure what else had the 351's trucks/vans for sure
mjr46 is offline
Old 10-13-2014, 02:49 PM
95gtconvert
but will it still work with the mustang transmissions I'm not going looking until I know the transmission will fit to the motor
Old 10-13-2014, 03:59 PM
mongolchuck
mongolchuck's Avatar
Yes a mustang transmission will bolt up to a lightning motor. But the lightning computer is for the e4od and won't run an aode or 4r70w as far as I know.
mongolchuck is offline
Old 10-13-2014, 07:43 PM
rmodel65
Yukon Cornelius
rmodel65's Avatar
and both the 351c and the 351w drop right in. they are both small blocks use the same bellhousing bolt pattern and the same engine mounts. and the heads will even interchange.
rmodel65 is offline
Old 10-14-2014, 08:38 AM
95gtconvert
alright so a new computer system to work with the transmission will most likely be needed or a manual will need to be put into my car to avoid the computer issue with an auto
