misfire problem
Hello!! Ok here is what is happening. I was driving my car home from work and it started to miss fire. I got home and opened the hood. I took my test light and started to cancel cylinders. 1 cylinder didnt make a difference (didnt make it rougher). I checked for spark at that cylinder and I have spark. So I then did a compression test and got 135psi which is within specs with the other cylinders (5 psi off). So with that in mind I am thinking I must have a fuel delivery issue. I took my upper manifold off and my lower. I took off the valve cover and cranked the engine over by hand. The intake and exhaust valves are opening and closing. So that leaves me with the injector. Injectors are 19lb injectors.
Please answer these questions.
1) What do I do to check out the injector?
2) What do I do to test the injector?
3) What else can cause this?
4) What else should I check?
Also if you have time. I have taken this chance to remove my heads and port and polish them and install my eldlebrock upper and lower manifolds(rpms) with 1.7 RRs and 70mm throttle body. Should I buy different injectors?? If so what psi?
Thanks for your time!!!!!
LOOK BEFORE POSTING..PEOPLE WHO POST NEW TOPICS - 5/19/2005 4:20:39 PM
vfast
Section Moderator
Status: offline guys, please do not mark your threads as follows
how hard
what about this
look here.
how fast
WILL THIS WORK
is this the best
I need help
what to do next
etc
state your topic or it WILL BE DELETED
thanks!!
< Message edited by vfast -- 8/28/2005 5:32:31 AM >
ORIGINAL: silver91gt
you know it is usually the small things people overlook that is the problem.
did you check to make sure all your spark plug wires were on good?
my truck had the same symptoms you described, turns out one of the plug wires came loose from the distributor.
before you ripped it apart, did you take out the spark plugs, clean them and re-gap them?
did you look at the condition of your distributor cap and rotor?
without checking these first you may as well just get a whole new engine.
because you will put all these new parts back on and it will still run like shi t and you will give up and sell it.
then someone who knows what they are doing will find the problem in 5 minutes and fix it for 50 bux. wont you be pissed then.
did you try cleaning your maf?
sometimes oil from the filter gets on the elements and causes it to run rough.
sorry to sound mean, but next time you make a post dont make the title "please read".
your problem is your engine is missing, so try "engine missing, need help" as a title.
most people wont even read this because it says please read.
didn't you read the stickie at the top of the first page for new posters?
Also before you assume that you know more about somthing than someone else you should try to consider everyone as an equal, and lose the attitude.
If you dont have anything useful, than go away so that people that wont waste my time can help me.
Later
Very easy way to check the injector. Engine needs to be back together and running. Just like you took the Test Light to check the cylinders you can check each Injector. You don't need the test light at first. Whatever cylinder had no change is most likely the culprit. With the car running unplug the injector and see if there is any change just like you did toi check spark. If there is no change, plug it back in and check to see if you have voltage getting to it. If you do then you most likely have a bad or clogged injector. if you don't then you need to check your PCM and Wire harness to the injectors.
I didnt mean it personally, so chill
to test injectors to see if it opens put 12 volts across the 2 tabs on the plug, you should hear it click.
if your girlfriends dad is a ford tech, why cant he help you???
Omgitsa88Stang
Oct 5, 2015 07:33 AM
Seanam
Oct 4, 2015 10:15 AM
stangin1996gt
Sep 21, 2015 11:01 AM
