Transmission/clutch question
Old 11-27-2014, 04:47 PM
SWGSSSlacker
SWGSSSlacker's Avatar
Default Transmission/clutch question
Hello and Happy Thanksgiving.
Story line: Got the 1990 5.0 notch back together after a 2 month engine tear down and rebuild.
Installed new trickflow top end kit on a fresh 308 block, new clutch, new lots of stuff.
Anyhow, got the car road worthy and drove it to Florida for Thanksgiving....... a good road trip engine break in. Starting out on the way to my destination and everything was going good until about 500 miles in I hit stop and go traffic. Until this point I had no issues with the clutch and tranny but the tranny no longer wanted to go in to first or second gear without effort. Thd clutch pedal seemed to get harder to push down as well. The cable is not in any sort of bind and I haven't looked at the clutch adjustment to see if it has un-adjusted itself yet. Before my road trip I drove the car all over town to made sure all was good and had no issues. I did have a higher then normal idle but got that taken care of with adjustments.
SWGSSSlacker is offline
Old 11-27-2014, 04:48 PM
SWGSSSlacker
Any ideas or suggestions?
Old 11-27-2014, 07:45 PM
dawson1112
dawson1112's Avatar
Was it a stock cable, or an aftermarket adjustable one?
It could be that the cable was riding against the header and heating of the sheath and cable caused problems, or it is misaligned in the firewall.
Also possible that the throw out bearing sleeve and bearing are binding up.
dawson1112 is offline
Old 11-27-2014, 08:21 PM
SWGSSSlacker
It's a stock cable. The throw out bearing and sleeve are new.
Old 11-27-2014, 08:23 PM
SWGSSSlacker
The cable wasn't and hasn't been anywhere near the header except for the normal position.
Old 11-27-2014, 08:41 PM
SWGSSSlacker
Now that I think about it I did not put any kind of lubricant on the sleeve during reassembly. Should I have lubed it with something? If so what? Some sort of graphite spray?
Old 11-27-2014, 08:45 PM
dawson1112
dawson1112's Avatar
If the cable has to much slack in it, it will make it difficult to shift because the clutch is not fully disengaging, but for the pedal to feel harder to push means something is not right. Check the clutch fork and make sure its still on the pivot ball. Take some slack out of your cable .
Dokilar
15
10-16-2015 08:13 PM
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
treesloth
09-28-2015 07:03 AM
Quick Reply: Transmission/clutch question
