spedometer is off
you can't...unless you get a speedo calibration box from someone that does cop cars
your car would need like a 25 tooth speedo gear and they only make 23's and those will break in an aod
it requires changing the drive gear and driven gear, an aod needs the output shaft replaced to change the drive gear
thanks ill look but if they dont have it i am pretty much screwed right? i dont know how far off it is but everybody passes me when i think i am going the speed limit that dont last for to long ha ha
Well find out how fast you are going.
Your gear set is
1st-2.40
2nd-1.47
3rd-1.00
4th-0.67
http://www.f-body.org/gears/
Your gear set is
1st-2.40
2nd-1.47
3rd-1.00
4th-0.67
ORIGINAL: im_stuck_in_iraq
the largest gear you can get is a 21 tooth(purple) for an aod , and those are for 3.27's (w/ your tranny that has a 8t drive gear)
how far off depends on what gearset you had b4.....but you could be anywhere from 10-20%off
Here is a post on which gear for what.
https://mustangforums.com/m_201146/tm.htm
You can get a 23 tooth gear gear from this site as well as others. It's close to the bottom.
http://www.transmissioncenter.net/sp...n_______va.htm
