BBK cold air intake experience
im considering a BBK fenderwell intake and i was woundering if i am going to need to do anything besides install it. will i need a tune up, will i need a new massa air flow meter, will i need extra peices, etc. please reply if you have done it yourself or if you know what your talking about. thank you.
no you will be OK. Its probally the simplest mod you can do to your car also. It will literally take 15 minutes if you know how. And its all common sense. You CANT mess it up.
the only mod you will have to do is remove the maf bracket.....everything else is direct fit....the bottom studs on ur old air box will unscrew with pliers........the kit will come with new screws.....
Sep 1, 2015 08:16 PM
