Dash lights
Old Aug 14, 2015 | 02:30 AM
1st 4 eyed fox's Avatar
1st 4 eyed fox
Default Dash lights
I just picked up an 85 4 eyed foxbody and my dash lights don't work I have ordered a new switch it should be here in a couple days but just curious of where else to look if that does not solve the problem. I have power across the fuse. If that don't work then I guess I will see if I have power to the light socket it self I just didn't want to tear all that out. Thanks in advance
Old Aug 14, 2015 | 03:51 PM
silver91gt's Avatar
silver91gt
if the headlights turn on, its not the switch that is busted. The dash lights run through the dimmer switch, then to the dash lights. I would suspect the dimmer is at fault if there is power on the fuse. the dash is real easy to remove and takes about 15-20 mins to do.
Old Aug 15, 2015 | 02:15 AM
1st 4 eyed fox
Default Dash lights
The dimmer and headlights are all in one package it has the know you pull out and twist for the dash and dome lights
Old Aug 15, 2015 | 02:16 AM
1st 4 eyed fox
Default Dash lights
*** not know sorry autocorrect
jwog666
Dec 27, 2021 08:09 PM
folivier
Oct 2, 2015 05:34 AM
jc409
Convertible Tech
Sep 26, 2015 08:28 AM
Sep 25, 2015 09:06 AM
accarter
Sep 21, 2015 11:56 PM
