Question about Valve Cover Breather
Old 09-20-2015, 07:24 AM
Ipaman
Ipaman's Avatar
Default Question about Valve Cover Breather
I have a 1993 GT that has been changed from EFI to Carb. One the driver side valve cover there is a breather. On the passenger side there is a PCV valve and that is routed to the vacuum port on the back of the carb.
My question is why is there smoke coming out of my breather? It isn't a ton but it is enough that you can see it coming out of the hood cowl. Shouldn't it be sucking air in? It doesn't spew oil or anything but I just hate seeing a puff of smoke coming out of my cowl all the time.
Thanks
Ipaman is offline
Old 09-20-2015, 08:35 AM
Phillip123
Phillip123's Avatar
Do you drive the car enough or does it just sit in the garage most of the time? It could be the condensation from the engine that is being opened up. The smoke usually goes away after you heat it and run it.
Phillip123 is offline
Old 09-20-2015, 09:04 AM
Ipaman
Ipaman's Avatar
I drive it about once a week. But the smoke doesn't really go away even after 30 minutes of spirited driving.
Ipaman is offline
Old 09-20-2015, 09:16 AM
Ipaman
Ipaman's Avatar
Here is a video of it. When driving and I really get on the gas it gets worse. Does this look normal?
https://onedrive.live.com/redir?resid=41F1F1B0241B6B60!5021&authkey=!AP3Nlne EsRvaoCI&ithint=video%2cMOV
Ipaman is offline
Old 09-20-2015, 09:31 AM
Urambo Tauro
Urambo Tauro's Avatar
What does it smell like?
Urambo Tauro is offline
Old 09-20-2015, 09:33 AM
Ipaman
Ipaman's Avatar
It just smells like normal exhaust fumes to me.
Ipaman is offline
Old 09-20-2015, 11:07 AM
Ipaman
Ipaman's Avatar
Actually I take that back. If anything it smells like gas.
Ipaman is offline
Old 09-20-2015, 11:54 AM
67LimeCoupe
67LimeCoupe's Avatar
You sure the pcv is connected to full vacuum and not just the air cleaner?
67LimeCoupe is offline
Old 09-20-2015, 05:47 PM
Ipaman
Ipaman's Avatar
Yea it is hooked up to the port in the carb. It was on the back port but edelbrock recommends using the front port so I changed it. There was no difference.
Ipaman is offline
Old 09-21-2015, 09:00 AM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
you need to make sure it is on the right port drawing manifold vaccum and not ported vaccum
mjr46 is offline
Quick Reply: Question about Valve Cover Breather
