Need help !!!
Electrical gremlins can be a major pain to track down. Did all this happen out of the blue, or did something change on the car ? New stereo, new alarm, remote start, etc ? All I can suggest for now is double check fuse box for blown fuses, verify any grounds you can find, even the connections by the battery. Do you have a multimeter for checking electrical current ?
check the grounds , try jumping the ground wire of something close maybe same part of harness to vehicle body , make sure it is a ground wire you are jumping though, if you jump it and everything comes to life put in a extra ground right there
Nov 7, 2015 12:18 PM
flash_xx
Oct 29, 2015 09:57 AM
