starter problems
Old Dec 29, 2015 | 09:19 PM
jarraun's Avatar
jarraun
Default starter problems
88 starter problem.
Old Dec 30, 2015 | 11:51 AM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
Originally Posted by jarraun
88 starter problem.
lol............................could you be any more vague than that? How about you provide details on the issue if you expect any helpful replies.
Old Dec 30, 2015 | 12:07 PM
Urambo Tauro's Avatar
Urambo Tauro
Welp, time to buy a new car I guess.
Old Dec 31, 2015 | 07:01 AM
88 orangepeel notch's Avatar
88 orangepeel notch
Since he called me by name, I'll grab this one lol.
What seems to be the problem with your starter Jarruan ?
And welcome to the forum, hope you can take a little teasing .......
Old Jan 3, 2016 | 11:57 PM
Richard1916's Avatar
Richard1916
at least check and make sure car is equipped with a starter first, or if someone stole it, alright lets get to work if 5 speed make sure in neutral ,take a screwdriver and jump one big terminal to the other big terminal on the solenoid located on the inner fender if starter turns stop jumping, if not starter is bad or cable to starter is bad or cable is loose, now the terminal that goes to the battery from the solenoid jump it with screwdriver to the small post on solenoid that has a 90 degree electrical fitting on it , starter should spin , if starter spins you probably have bad ignition switch. or maybe fusible link
jrp79
Dec 2, 2015 11:53 AM
Zachv1
Jan 4, 2006 10:19 PM
redmustang83596
Aug 11, 2005 02:49 PM
Bo408
Sep 2, 2004 09:19 PM
five0man
May 15, 2004 08:09 PM
