Lower Intake Gasket Question
Old Jun 28, 2016 | 04:13 PM
UltraBlue91''s Avatar
UltraBlue91'
Default Lower Intake Gasket Question
Hey all,
I'm looking for people's opinions on the best way to install the lower intake gaskets on top of the heads without causing them to move around when putting on the lower intake or so that there will be no vacuum leaks when finished. Tell me what worked best for you and I know there will probably be a couple different opinions on this. Use RTV? If so in what spots. Use weather adhesive on the gaskets to prevent them from moving? Or a form of fast drying adhesive?
Old Jun 28, 2016 | 04:20 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
put a piece of threaded rod in the bolt holes and drop the intake straight down...rtv around the waterports and rtv instead of the cork gaskets on the ends of the intake
Old Jun 28, 2016 | 06:14 PM
dawson1112's Avatar
dawson1112
I always use a couple studs on each side.
Old Jun 29, 2016 | 05:12 PM
UltraBlue91'
Thanks guys
Old Jul 1, 2016 | 07:24 AM
Boss_Hotrod's Avatar
Boss_Hotrod
I used some blue permatex stuff from advance that is a fuel resistant rtv. Comes in a white/gray and orange package. Put that on both sides of the gaskets and then did what the other guys said. I also torqued them multiple times then ran car until it got up to temp. I then pulled upper intake off and retorqued the bolts while the engine was still hot. They moved a little. Haven't leaked yet.
Old Jul 1, 2016 | 11:16 AM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
studs as stated and get some edelbrock gaskacinch and glue them in place before setting intake
rydahog
3.7L V6 Technical Discussions
May 8, 2016 09:46 AM
ndnboy
May 4, 2016 04:57 AM
08hybridok
Apr 29, 2016 10:09 PM
96'BlueGT
Apr 22, 2016 09:23 PM
carid
Apr 18, 2016 08:16 AM
