upgrade 88 to 89 engine
RE: upgrade 88 to 89 engine
i put a motor out of an 89 vert in to an 88 gt...it runs fine...but if you got the motor all you really need to do is convert it to mass air...and you got the same thing...it is probably cheaper to buy the conversion kit than to go out and buy a complete 89 motor with all asseccories and hook up...i would just install the conversion kit..
An 88 and an 89 are identical motors. As stated by others the only difference is speed density vs mass air. You don't have to convert the entire motor. All you need is the mass air meter and harness from the 89. maybe some other things as well. maybe someone who has done this conversion can chime in.
ORIGINAL: 95whitecobra
09-01-2015 08:16 PM
