Camshaft Removal
yea fan and fan shroud is off, so is radiator, damnit are you serious i gotta take the lower intake off? i just put it back on finally, will i have to replace the gaskets again? i hope not
ORIGINAL: 16FoxBody
you don't have to touch the engine mounts
1. remove rad,hose..put in a 180 mr gasket stat
2. intake,t/b.etc
3. pull dist
4. valve cover
5 wather pump
6. remove ham.balancer
7. timing chain cover and chain
8. loosen rockers arms to pull push rods
9 pull lifters out
10. find a bolt to fit in the cam to pull it out not to nick any cam bearing
11. use moly lube on cam and lifters
2. intake,t/b.etc
3. pull dist
4. valve cover
5 wather pump
9 pull lifters out
You need to take the valve covers off lossen or remove the roker arms then take the push rods out and the lifters need to come out and it is good toput the lifters and the push rods and rockers back in the same spot they come from and yes unless you got the tool to get the lifters up with out taking the lower intake off you will need to remove it also the distributor needs to come out.
When i removed my valve covers my rocker arms ARENT there, y the hell is that? alslo to get the push rods out do i just loosen the bolt on top off the spings and pull the bolt out? or just loosen it?
