.514/.544 224/230@112 WILL THIS WORK?
Old Oct 29, 2005 | 08:51 PM
grabbem88's Avatar
grabbem88
Default .514/.544 224/230@112 WILL THIS WORK?
i just want to know if this would work..my cam unfortunately is a 1.7 cam,but i already spent the big money for the D.S.S 1.6's before i bought the cam.
what i wanted to do was just install 1.7's on the exhaust side. or would using on both sides
give me more power?
the only other option is install a custom cam. whoever knows there cams give me some advice.
Old Oct 30, 2005 | 12:09 AM
grabbem88's Avatar
grabbem88
Default RE: .514/.544 224/230@112 WILL THIS WORK?
well does anybody want to buy my cam ?
Old Oct 30, 2005 | 05:12 AM
Black Snake's Avatar
Black Snake
Sounds like a good idea never heard of it being used but if you give it a try let me know how it turns out.
Old Oct 30, 2005 | 05:14 AM
grabbem88's Avatar
grabbem88
i'm just wondering if it's too much on the ex. side.
oh it works people have done it,but i have too much in the motor,and not enough to replace.
Old Oct 30, 2005 | 06:55 AM
95whitecobra's Avatar
95whitecobra
the .514/.544 is with 1.7 rr's? If so, then with the 1.6 rr it would be approximately .502/.525 lift. If you split the rockers they way you want it would be .502/.544. IMO, I would use the new 1.6's you just got...or exhange for 1.7's DSS allows you.
Old Oct 30, 2005 | 08:10 AM
grabbem88's Avatar
grabbem88
no with 1.7's it's .544/.544 i am using 1.6's right now so it's .512/.512 or .514/.514? i figured it to be one of those.
Old Oct 30, 2005 | 08:14 AM
grabbem88's Avatar
grabbem88
ok you confused me i thought it was .30 thous between 1.6's and 1.7's?
Old Oct 30, 2005 | 12:59 PM
vfast's Avatar
vfast
I ♥ Acer
sounds like a mess....return all that stuff..use the 1.6 rocker and find a cam for 1.6's no custom cam needed
Old Oct 30, 2005 | 05:14 PM
95whitecobra
ORIGINAL: grabbem88
I didn't know you had already calculated the lift with the offset rockers to get the .514/.544. I would stick with the 1.6's you have now. Are they hurting performance. Spending $300 just to get and additional .30 lift might not be worth it. Changing from 1.6 to 1.7 makes a noticeable difference on a smaller cam with like stock lift.
Old Oct 30, 2005 | 06:15 PM
grabbem88's Avatar
grabbem88
it's all been on my car for a year performance is great.just seeing if i can get more out of it. 318/328rwhp is what it's making now,and i didn't think it was bad? i'm just going to leave it alone,and get a s/c!
