HOW much should this add (Power Pack)
ok this is all the parts i have bought for my stang and just dont have the time to put them on till the 2 weeks off at christmas...
Cobra Intake manifolds
70mm Mac Throttle Body with EGR
Mac Fenderwell Mount Intake
3 peice pulley set
AFR 165 Heads with 1.6 FRPP
BBK Heads
73mm MAF
24lb injectors
FPR
i think it should set me close to 320 my bottom end is super strong and has nothing but sythetic run through it so.... what yah guys think?
Stalion
3 peice pulley set
BBK Heads
73mm MAF
24lb injectors
FPR
Stalion
RE: HOW much should this add (Power Pack)
probably wont even be over 300 hp. I have all the same mods to my car besides the heads and i went from 223 hp/303tq- and after tb, exhaust, headers, underdrives, trick flow intake, 73mm mass air, and cold air my numbers went to: 244hp/326tq. i almost think spending 1500 dollars for 21 horsepower was a waste of money. you need a cam to go with those heads and your 300 hp mark will be more ideal.
RWHP???
WTF???? if those numbers are right iam going rice.... that sounds to low... all test i have seen done with intake swaps and heads... produce aleast 50 over stock....
Stalion
are we talkin rear wheel horsepower?
Stalion
Stock heads? EWWW
oooo just read your post better.... yah you jsut have a manifold and stock heads? yah thats y your power numbers are so low...get some 40X heads or AFR and that sucker will be up near 300 (290) or afr is supposed to claim a bolt on 60 horses...
iam having my mustang tuned by diablo when i get this done to hopefully set me close to the 300 mark
adam
adam
RE: Stock heads? EWWW
heres some tips for you itailianstallion
those numbers dont believe them always. mags and companies LIE and so do cops
you have things that should be changed out. a 73mm with a 70mm,24#ers
one with that setup a 65mmtb would be better, injectors dont add power. your power adders on that list are Heads,Intake. others are just freeing up HP
also you dont need a egr spacer with a cobra intake
hmmm
i meant headers... sorry... but yah i based my power pack off the ford racing bold on 110 kit... i figured for right now the cobra manifold is all i need right now... the afr 165's are nown to be better then 40X heads, 1.6 rockers... and then just the other free uppers.... i thought with the heads and stuff should atleast bolt on 120 which would sit me near 320 or alittle over...
Stalion
Stalion
RE: hmmm
you wont see no 120gain with just heads. just no way. stock cam can make power if properly tuned right
you can have the best heads in the world dont mean youll make the power they are suppose to if setup is wrong
