87 5.0 needs serious help
Ive got an 87 gt 5.0, with a 5 speed trans. Its engine swapped with a cobra engine from a 93. Its got serious issues, I just recently bought the car after it had been sitting in a field for 5 years. It has a serious misfire but I don't know what cylinder. Ive tried getting codes off of it but the hookup for the scanner doesn't get power so i'll get codes once the connection has power once I figure out why it doesn't. The whole car is in rough shape and im trying to Bring it back to life but its in seriously rough shape. From what I know it has a very serious misfire, doesn't idle (stalls as soon as it starts and you have to keep it alive by giving it gas constantly, once its warmed up it idles on it own for a short period of time. when given gas to keep alive it jumps up to 2.5k rpm then drops to about 500 and wants to stall.) it also runs extremely rich and fouls plugs like you wouldn't believe. I don't know what the timing is set at. anything helps thanks.
I'd just check for loose connections, broken vacuum lines, clean your maf. New plugs wires and check the timing to start (after new fluids etc). Did the previous owner swap everything over from the cobra? They have a different computer, throttle body, injectors, maf if everything wasn't swapped it could create issues as well.
87 was speed density. cobra engine with a stock speed density set-up, could maybe cause some problems. the computer didn't get a signal from a speed sensor then either i think. that could cause some problems too i imagine with the swap
