cool air intake
Old Dec 30, 2003 | 11:34 PM
bobby's Avatar
bobby
Default cool air intake
hi yesterday i installed a bbk cold air intake, fenderwall mount, and k&N, when i rev it up it pauses and makes a hiccup noise like its sucking for air then revs up is this normal. also i installed msd distributor cap, coil,and wires.what would be the best timing isnt stock 10, but i heard that ur suppose to bump it to 12degrees,any help would be great thanks.
Old Dec 30, 2003 | 11:40 PM
mkspeed26's Avatar
mkspeed26
i had the same problem with my gokart. we are ordering a new carb for it. i think the engine is running too rich. what year is the car?? if it a carb engine lean out the mixture a little. if it is efi i dont know.
Old Dec 31, 2003 | 06:06 AM
Quik's Avatar
Quik
you might have a leak. in the intake. check your connections. different cars react to different timing. i have mine set at 15 anything less its slugish. some like 14 some like 12 and etc. set it and drive it then adjust to you feel good with it. jsut make sure you dont hear a pinging sound[sounds like a spray paint can shaking] if you do back out timing
Old Dec 31, 2003 | 09:56 AM
Black92's Avatar
Black92
Just a thought, alot of car have this problem due to restricted flow on the other side of the engine. have you looked at your exhuast setup yet.
Old Dec 31, 2003 | 05:21 PM
mkspeed26's Avatar
mkspeed26
</P>
good thinkin, could be clogged cats er somethin</P>
Old Jan 1, 2004 | 03:39 AM
95Stealth302's Avatar
95Stealth302
if its only for a brief moment, you hear the cool sucking noise like when you take in a deep breath really quickly, its perfectly normal. Thats just what happends when you put on a low restriction air inlet. Perfectly normal. </P>
My timing is at like 13 or 12and I'm getting some pings, need to back it off a bit I think.</P>
04stangman
Sep 17, 2015 01:45 PM
kevsgt
Sep 9, 2015 06:20 AM
Sep 8, 2015 11:50 AM
Sep 1, 2015 08:16 PM
