any one have a kenne bell BLOWZILLA need help ???
hello i have a 94 gt ( some say its a dog ) but i love it i wanta
put a supercharger on it put i wanted 2 try something diff.
not a pro charger or vortex i want to be alil bit diff . if any one could help me
thank you .....
the supercharger i want is The BLOWZILLA from kenne bell
thank you .....
RE: any one have a kenne bell BLOWZILLA need help ???
I think if you start getting up around 400 HP, you'd want to have the internals forged (crank, rods, pistons) maybe one of those braces to strengthened the block too so that it won't crack.
You will need new head bolts and gaskets also. You will need a new clutch because the stock one will fry over a short time.
You will want to open the exhaust for better flow. You will need to upgrade the fuel pump as well, which probably comes with the kit.
Put some good synthetic in the transmission because you will be working it hard.
Wider tires help you control your burnouts when you light it up and while make a turn, lol.
How much HP do they estimate the Blowzilla to be?
