i'm planning on buying a stroker kit from dss racing. they offer to balance the kit for $175 extra. should i trust that or take it to a machine shop myself?
Best have the harmonic balancr that you aare going to use and the flywheel/flex-plate too. That all needs to balance togather.
About $150-175 is what they get anyplace around here.....
Many correct answers here, best way is to have individual pistons and rods set to eqaul weights and then balance assembly with harmonic balancer and flex plate (or flywheel clutch, pressure plate)
so should i trust the company to balance it for $175 extra and take it to the shop or just take it to the shop myself?
Depends on if you are getting all the parts I listed in previous post from DSS. You want all the parts and the rotating assembly as a whole to be balanced. If you are not getting all the above from DSS I would take all to local shop.
