oringed?
i am having some headwork done to my stock heads and i plan on running nitrous. a friend said that they should me oringed so when i spray it wont blow a headgasket is taht true? or is it ok if i don't have it oringed?
p.s i am having them milled 40 thousands, ported, 3 angle valve job and bigged valves put in 1.85 1.60
Having them o-ringed is definitely good. Not sure it is a must but definitely good.
The next best option is receiver grove in head and run lock wire gasket. If you have the heads off and are doing that much work, you should go for o-ring or receiver groove.
I have both options running 13 - 15 psi of boost, both working okay.
what is the difference?
I thought o-ringed heads accept loc wire gaskets. doesnt it mean there is a groove cut into the head, and the gasket fills the groove so it wont blow out?
what is a reciever groove?
ORIGINAL: silver91gt
Receiver grove is only cut in head. The lock wire gasket has a metalic ring that fits into the receiver grove, the gasket is normal head gasket for sealing. The reason this works is becasue it keeps the gasket from walking under load and changing conditions.
Sorry I missed this earlier, the o-ring grove is in the head for mine. Fel-pro makes a gasket for this application (1006) it uses metal to fill the o-ring groove.
ORIGINAL: Jasperstang308
i asked the guy at the machine shop today about it and he said that the oring is in the block not the head but that doesn't sound right to me
doahdogg
Jan 28, 2009 09:40 PM
