Injectors
Ok I'm looking to get some 3.55 or 3.73 gears along with some 1.6 roller rockers, E cam and throttle body with spacer. After all that is done do you guys think that I should get some new fuel injectors or would I still be safe with what I have. After all those mods are done I'm looking to get the upper and lower intake manifold. Any suggestions?
I'm thinking I will upgrade to the 24# if I do do the cam because sooner or later I'm getting the upper and lower intake and I rather have the injectors before I do that.
if you do go with the 24 pounders and it is just a little rich...then get a adjustable fuel pressure regulator and turn it down and you will be just fine...because you will adventually need them...so it is better to have them and and hold them back than to need them and not have them....
ORIGINAL: mallory
