need tips
RE: need tips
http://myspace-867.vo.llnwd.net/0033...32268867_l.gif
Not sure if oyu will be able to bring it up, but on a bone stock unworked engine Tmoss ported made like 216 RWHP with 290 Ft Lbs
This guys has the following:
Long tubes
65 mm TB
76 Mm Maf
Underdrives
Steeda #19 Cam
Thumper heads ( Stage #2)
SPECS on heads Thumper Ported E7s (219/155 cfm)
Performance Vassco dual springs, moley keepers and retainers
For cams to .600 lift (not included)
Stock valve size for the Killer low end throttle responce, and the flow for the mid to top end
Optional - Machined for Screw in studs and guide plates (for adjustable valve train) - Add $100.00
Optional - Roller Timing Chain Gear Set w/3* Key way (for advancing /retarding Camshaft) - Add $64.95 + shipping
$695.00 + 100.00 refundable core charge
The above dude ran 255 RWHP and 300 Ft Lbs of Torque
Long tubes
65 mm TB
76 Mm Maf
Underdrives
Steeda #19 Cam
RE: need tips
Most definiatly those thumpers are just worked E7's ( Stock heads) Go to a local machine shop and get a quote for a valve job, new springs, Milling, and porting and see what they will charge you.... those Stage 2 heads are pretty cheap and flow nice numbers.... And 200 bones for a ported stock is cheap as well.... with all that you want and suspension mods as I listed you will be rocking 12's plus it looks stock as well you would F()ck alot of people up.... just be like yeah its bone stock dude, just got UD's and headers....
