Smog Removal!
Smog Removal!
Hi i been hearing a lot about smog removal. Is it really worth the time to uninstall it, and what do you gain from removing it??
[IMG]local://upfiles/25164/6BFDF860380B4D7880906066AE028DA6.jpg[/IMG]
RE: Smog Removal!
Less rotating force, its really not that much of a gain just a cosmetic gain, cleans up the engine bay alot. The was the first thing I tore outta my stang second the A/C then the CAts.... God I hate Cat's and Smog systems WTF
RE: Smog Removal!
Smog doesnt really do anything other than make the vehicle more environemental friendly, you just have to remove it properly... First remove pump and plus all vaccum lines going to it. Then remove the piping to the back of the heads and plug those holes with a bolt or some people have used cut off spark plugs but you can buy special plugs for it. THen cut off and plug the tube going into your exaust pipe. its all done from there remove it all outa the engine bay and it looks a million times better and you have a bit more power. Plus then engine is easier to work on after thats out as well....... I have no EGR or smog system on my car.
RE: Smog Removal!
ORIGINAL: FastFox
I heard that it isn't a good idea if you still have the stock heads, though.
RE: Smog Removal!
you can bypass it for the track but thats about it
if you remove it all youll have to do what schwindty said along with remove the lower intake and putting the blocking gaskets over the EGR hole
also have to make a plate for the egr spacer an then take apart the valve and sensor and just plug sensor back in and make sure sensor is fully closed and you wont get any check engine lights
