4cyl to V8 swap
4cyl to V8 swap
ok last weekend i took the motor out of my peice of crap 91 Hatch and put it in an 89 Coupe that used to be a four cylinder, all of this in 3 days...so now that the motor is in the new body i cannot get it to start....i have no clue whats up....i dont get a fuel pump with the key on run and i dont get the motor to turn over when i turn the key...so guys heres where you come in...what do i check next??? i have gone over all my grounds and yes the fuel pump comes on when i cross the relay. But if anyone has any helpful info...or something that i should check please help me.....thanks....other than that i love the coupe...nice and clean and a better car overall.
RE: 4cyl to V8 swap
Have you just gone over everything again? I mean to swap a motor in 3 days is pretty damn fast. I would go through EVERYTHING and you might of forgot something small. I would do that and see what turns up.
RE: 4cyl to V8 swap
ok went thru grounds again....checked the inertia switch for the fuel pump and all fuses.....yes the harness was switched over to the new car and im not even worried about spark right now because i cant even get it to turn over....i can turn it over from the EEC relay inside the car and it will fire but the starter stays on when i cross the wires so i cant leave it running.....it just seems like the car doesn't know that i am turning the key....because the key wont send a signal to any of the relays. so yea....im lost...ive been staring at wiring diagrams and following wires for 2 days..and i want it to run now
