Money to Burn
Money to Burn
hey, i got in a minor accident awhile ago and the guy rearended me so im gonna collect the money off of it. ill probably replace the bumper which is $160. are those easy to install? but ill have about $300-$350 to spend. what should i buy with that money? i want the most hp.
RE: Money to Burn
ORIGINAL: 50fiend
Me a ticket to fly where ever you are so I can drive that black stang. That thing looks sweet.[sm=gears.gif]
RE: Money to Burn
if u were rear ended then it is probably more than 350 in damage because the actual bumper underneath is probably damaged then paint is about 150 so ur looking at about a grand in damage u can also tell the insurance company to use ford part only in the quote instead of aftermarket cause they will definitely fit better as for ur question about installition the cover just bolts on u have to remove the rear trim n the hatch area lift up the carpet and spare cover i belive there is somthing like 14 bolts inside eight across the hatch bottom floor three down each wheel well some plastic push in body snaps on the very bottom of the bumper and maybe two boths holding the bumper to the rear ground effects on each side
RE: Money to Burn
well i didnt get rearended too hard. the bumper cracked in two places. both tail light have minor cracks. the whole thing isnt really too noticiable. ill try to get pics up.
