Which would be better?
http://store.summitracing.com/default.asp?Ntt=M-7553-B3&searchinresults=false&Ntk=KeywordSearch&DDS=1&N =115&target=egnsearch.asp&x=23&y=5 Which are rated at: Front 425/530 Rear: 200/300
-OR-
http://store.summitracing.com/default.asp?Ntt=M-7553-B3&searchinresults=false&Ntk=KeywordSearch&DDS=1&N =115&target=egnsearch.asp&x=23&y=5 Which are rated at: Front 650 Rear: 200/300
I'm looking for the best drag and overall handling out of these springs. Thanks.
-OR-
RE: Which would be better?
I'm pretty much looking to be able to lay the power to the ground before I get any more you know power. Would the upper and lower control arms be beneficial? Anyone know where I can get them for cheap. Summit has their name brands form 245 and BBK is 295. Im also looking to fabricate some sub frame conectors.
ORIGINAL: Crazyfast50stang
-OR-
-OR-
people are selling the summit control arms on ebay for 139 and saying they are granatelli motorsports arms. thats what i bought and they are great. if you want to buy some cheap subframes go to www.blueovalindustries.com
Hey thanks. Their website has been down though. I've been trying to go there but hasnt worked. The only place I can see them at is on ebay. I'm going to look into the summit control arms. Does anyone know anything about the spring ratings and which would be good for drag?
always good idea to up -grade to better bushings on your differential ears. I installed the poly-urathane on mine. I also have seen the billet or syperical ones. But thought that they might be too much for Street use and Harsh. Good luck!!
