n20 on 347?
RE: n20 on 347?
with hyperutectic pistons I would say a max of 100 shot
with forged pistons, a 10,000 shot.
no, realistically, I wouldnt go over a 150 shot, unless you have a forged crank and forged I beam rods, then you could go till you split the block.
we need more info though, what heads, what other stuff are you running?
RE: n20 on 347?
Nitrous is hard on one thing.......the people that dont know how to tune it. I sprayed my car over 50 times. I just pulled out the motor to go through it. It looks like new. Back off your timing 4 degrees and make sure you have enough fuel going to it....I wouldnt go anymore than a 100shot. Make sure you get a WOT switch or a window switch. I am going with a supercharger because filling the bottle is costly and I want power all the time.
RE: n20 on 347?
my 347 has stock block,10.5 to 1 forged pistons.steel crank,main-gidle,billet flywheel,fluid damper,stage 3 trick flow cam(298/310 dur. and .574/.595 lift)1.7 rollers,Avenger heads w/2.05 valves,trac heat intake w/36lbs.injectors,70mm throttle body,Crane HI-6 ignition box,Long tubes!!!
RE: n20 on 347?
ORIGINAL: RacerX
