Its got world product heads on it don't know what springs. With a good set of springs on it how big of a cam do you think I can run. Its also a stock shortblock.
I might need to clean them off some more, but i have look on the side of the heads and there isn't a number. Below the guideplates it says windsor jr. Is there another place the casting # would be.
it will be hard to see what cam it is, those numbers arent the cam number.
my b-303 cam had a number like that, but it didnt match any of the part numbers or anything.
use a depth micrometer and a degree wheel, then you can find the lift and duration, then compare it to some cam specs.
