When car sits for running for about 2-4mins idle will drop and car then runs crappy, help!
I dunno if that will help, but i guess it wont hurt to wait for the idle to drop and then raise it. Its just that the idle will be normal and then it will drop pretty low 400-500 and the car will shake back and forth like it has a crazy cam in it, but it will run like crap after the idle drops. I dunno well see.
if the idle is at 800 right when you start the car with a cold engine and then drops to 400 to 500 you just need to adjust the set screw for the thottle body. Open it up a little. On a cold start the initial idle should be anywhere from 1000 to 1300 then should drop down to 800 after a few minutes. Hope that helps.
Yea I understand the morning cold start but this happens whenever the car is sitting mainly when hot, at longer stop lights, or even in my driveway while it sits for about 2-3mins. This morning I let the car sit for awhile and like usual the idle dropped, so I adjusted the idle after this drop to where I wanted it, I then checked the TPS volts and it was at 1.05 (with car off) The crappy thing is I go to adjust the TPS volts and the TPS screws are stripped(not from me) and wont turn. So now I dunno what to do, so I just set the idle back down.
I had the same problem...Did a thousands things still cant figure it out...I was jumping from 900-450 then stalling out..I just lowered my timing a lil bit and raised the idle...Now it does it from 800-900 .......So if u figure it out let me no......I did eveything PVC vavle, cleaned throttle body, fuel filter, checked for any leaks, cleaned IAC, checked plugs and wires, It runs find tho when i have the spout out and the computer wasnt hooked up, i was starting to think it was a computer issue....
ORIGINAL: ZeroSk8er823
Update:
Im a extremely frustrated. Ok so this morning same thing missing stumbling all over the place while driving around town, I get home and call my stepdad who is a mechanic and I decide to take it to his shop. On the way there runs fine. He checks some things, including a check for codes. No codes. Then I take him for a ride and nothing the car runs fine. WTF!!! On the way home also runs fine. I dont get it.
Update:
