tps adjustment
RE: tps adjustment
you need a volt meter that is digital it makes it easyer, put your black lead from the meter on a ground and pearce the green wire on the tps with a needle and put the red lead on that. then set to .98volts i do belive that is dc currant someone check me on that.
RE: tps adjustment
first off you will need a multimeter then you have a red black green wire on you tps with the black wire off your multimeter put on groung of your battery and check the red wire and see if you have voltage goin through it fist then you test the green wire and turn the key on but dont start the car and you sould have a reading of .98---.99 if not then losen the two bolts and move it around till you get get this reading!
RE: tps adjustment
ORIGINAL: Tims 88GT
RE: tps adjustment
It doesnt look like there is much room for adjustment so will I have to slot out the holes. and I have one off my spare intake do these go bad typically? I want to save extra parts
RE: tps adjustment
ORIGINAL: ZachW04Stang
You shouldn't have a problem turning it even though there isn't much room. Do not use a analog multimeter.
whats wrong with using an analog multimeter? Any multimeter will work just fine if you know how to use it. Analog or digital with today's technology even a $20 meter will do just fine. The older analog meter's are still very accurate even compared to a $300 digital meter today. I have a 20 year old simpson analog meter and a $200 digital fluke, im just wondering why you say dont use a analog multimeter.
RE: tps adjustment
ORIGINAL: 89stanglx
cuz it's awfully hard to adjust to less than 1 volt....or w/in a 5th of a volt for that matter w/ a needle and guage......
digital is a readout...plain and simple.
and my digital multimeter is a $20 craftsman
it has to be digital...unless your analog meter was like 0-5 volts , but i have never seen such a dog
