Carbureted 5.0
Old 12-22-2005, 03:13 PM
jlauth
jlauth's Avatar
Default Carbureted 5.0
Ok my brother has a 1979 cobra with a carbureted 5.0 and he an I were wondering which mods would be the best for his car. We know that is had a mild cam, 4.10 gears, and straight pipes. We were thinking engine swap or just rebuild. We were thinking we could bore it out, add new heads and maybe a different cam and HP parts (maybe nitrous). I don’t know no much about mods on carbureted motors.
jlauth is offline
Old 12-22-2005, 03:16 PM
88BlueGT
88BlueGT's Avatar
Default RE: Carbureted 5.0
Well, IMO. Any classic car deserves a 351W (just my opinion). But if you want to keep the 302 block that stroke it (331,347), put a nice cam in there, some AFR 185's, keep the 4:10's, nice eddy victor jr manifold, and he will be set.
88BlueGT is offline
Old 12-22-2005, 03:44 PM
SchoolBoy
SchoolBoy's Avatar
I say just leave it a 302, put the AFR 185 heads, and manifold made for the RPM range that you want, and top off with a 650cfm carb, it'll make a hell of a difference......
SchoolBoy is offline
Old 12-22-2005, 10:14 PM
vfast
I ♥ Acer
vfast's Avatar
for what you have the 165's you be good or build up a 351 with some 2.02 heads or 2.05's
vfast is offline
Old 12-22-2005, 10:28 PM
viking396
viking396's Avatar
Depends on what block he has, hopefully it isn't a '79 block. I've had several '85 Mustang's and the last one was treated to a replacement Ford 306 roller motor, E-303 cam, GT40 heads (nothing done to them), Performer RPM intake, Barry Grant rocker arms and stud girdle, manual steering, full length headers, Barry Grant 650 double pumper, electric fuel pump, 3.73 gears, Mickey T street drag tires and a newer 8.8 inch rear end (85's had the 7.5, ugh)...
That sucker ran 12.5's@111 all day long, not too shabby for the cost of a rebuild. 302's are cheap to build and can run 12's with so little effort it isn't funny, make sure to get the roller motor of course.
viking396 is offline
Old 12-23-2005, 01:03 AM
mkspeed26
mkspeed26's Avatar
he should definately drop in a 351W. it would bo SO easy too. if you wanted to stick with the 302, just slap on some heads and an intake. that would give him a good amount of power
mkspeed26 is offline
Old 12-23-2005, 01:27 AM
Quik
Quik's Avatar
first thing i would do is find a roller motor. thats MHO then do a 306 rebuild and do some GT40 heads or some HIPOs along with a 289 intake, 600 or 625 carb along with a cam with specs of 226-230 duration with a lift around .500-510 and a LSA of 114-112 this would be a stout combo. not the strongest but very streetable with a nice lope and great solid midrange usuable power along with some good topend power
Quik is offline
Old 12-23-2005, 02:57 AM
jlauth
jlauth's Avatar
ok, thanks i will send him the news that he will be seeing the mid 12's in not time. Im sure that he will like to here that.
jlauth is offline
Old 12-23-2005, 07:37 AM
Quik
Quik's Avatar
but if he cant drive he'll be like every other mustang owner and have over 300 hp and only get a 13
Quik is offline
Old 12-23-2005, 11:29 PM
jlauth
jlauth's Avatar
he can drive just fine trust me
jlauth is offline
Quick Reply: Carbureted 5.0
