Need Transmission recommendation
I have an 1989 LX 5.0 w 80K mi. The transmission needs a rebuild. I was wondering if any one had any recommendations on high performance transmissions. I might replace the trans altogether if there are some solid options. Car is a daily driver.
RE: Need Transmission recommendation
2800 dollar value, only 5k in miles on it
what you think its worthwhat you think its worth
GER AOD.....
3200 nonlockup stall
solid 1piece input
2.84 svo first gear
wide ratio OD
trickflow deep pan
lentech VB with OD lockout
larger OD band
they claim this tranny can hold between 500 to 600 hp
i might also let the 24,000 gvw tranny cooler go with it/maybe also the auto meter 2 1/16 tranny gauge
GER AOD.....
solid 1piece input
2.84 svo first gear
wide ratio OD
trickflow deep pan
larger OD band
