Just used seafoam have a ?
Old 12-29-2005, 06:16 PM
primetime5.0
primetime5.0's Avatar
Default Just used seafoam have a ?
just got done using it and my car hardly smoked..... what gives?
primetime5.0 is offline
Old 12-29-2005, 06:33 PM
Reef
Reef's Avatar
Default RE: Just used seafoam have a ?
more than likely your engine was alot cleanr than you thought
Reef is offline
Old 12-29-2005, 06:38 PM
evil monkey
evil monkey's Avatar
what is this sea foam you speak of?
evil monkey is offline
Old 12-29-2005, 06:40 PM
primetime5.0
https://mustangforums.com/m_886999/m.../tm.htm#886999
Old 12-29-2005, 09:55 PM
90GTRagtop
90GTRagtop's Avatar
How did you do it? Did you do it like this?
With engine warm, slowly pour 1/3 to 1/2 pint through carburetor or throttle body throat. (If vehicle is port injected slowly pour SEA FOAM through direct manifold vacuum line that will feed all cylinders, possible sources are P.C.V. valve or brake booster line.) This will pull SEA FOAM down on top of the pistons and to the back of the intake valves to dissolve carbon. Turn ignition off. Restart engine after 5 minutes. If severe carbon build up is apparent, use more Sea Foam as previously directed. Make sure exhaust is well ventilated when using Sea Foam in these various ways as fumes will be extreme for a short time.
From the SeaFoam Site; http://www.seafoamsales.com/motorTuneUpTechGas.htm
If you pulled it directly into the intake through a large vacuum line like the brake booster line, it will usually smoke up. If you don't pull in a high concentration, it won't smoke at all.
90GTRagtop is offline
Old 12-29-2005, 10:03 PM
primetime5.0
i did it just like that, barely any smoke
Old 12-30-2005, 12:07 PM
stanglx2002
stanglx2002's Avatar
i normally pour about half a bottle into the TB and let it sit for 5 minutes and it smokes like crazy
stanglx2002 is offline
Old 12-30-2005, 12:14 PM
88BlueGT
88BlueGT's Avatar
I dont have my mustang to try it on so I think I will try this on my Intrepid
88BlueGT is offline
Old 12-30-2005, 12:41 PM
5.0 MPG
5.0 MPG's Avatar
Since my Mustangis in paint I tried it on my lawnmower, awsome stuff!
It cleans bathtubs too.......
5.0 MPG is offline
Old 12-30-2005, 01:23 PM
chord509
chord509's Avatar
It's amazing how much it brightens your smile, too! [sm=alcoholic.gif]
chord509 is offline
Quick Reply: Just used seafoam have a ?
